Both of the #4 body bolts had to be cut off. The cages holding the body nut were badly corroded and now I'd like to replace them. I'm going to remove both deck hinges and noticed three bolts holding the hinge assemblies to the body, one vertically down through the body and the other two horizontally attached to the rear of the body. I've soaked these bolts as best that I could with penetrating oil. It appears that the outer hinge bolts could be difficult to remove becasue of the limited access. Are any of these bolts typically corroded tight and prone to breaking? Any one have any tips on accessing the outer horiz. bolts? Flexible socket, etc.? Note that the body is off of the frame.
Dave Kitch
Dave Kitch
