1966 cpe glass date code / proper placement - NCRS Discussion Boards
  • Paul #8304
    Is the 1966 corvette cpe drivers door glass date code readable from the inside or the outside of the car? Thanks
  • Jeff Grablick
    Re: 1966 cpe glass date code / proper placement
    Paul,
    I just checked my '67 coupe and found the date code is readable from the inside lower front corner each side. The vent window glass is readable from the outside. I believe this is correct, you should get additional responses.
    Jeff
    • Jeff Grablick
      Paul,
      Jeff
