56 distributor hold down and manifold holes - NCRS Discussion Boards
  • Steve Junkersfeld
    I have looked in the tech guide for details on two items with no luck. First - what color is the distributor hold down painted? I would have guessed satin black, but on page 156 of Noland Adams guide, there appears to be a silver one. It's hard to tell from the photo. Second - on the driver's side of the distributor, there are two threaded holes in the intake, one of which goes all the way through the manifold to the lifter galley. I believe these holes mount the powerglide linkage bracket. Since my car is a 3 speed, do I thread bolts into these holes? Any insight into these two questions would be apppreciated. Thanks Steve
  • Ed H.
    • November 1, 1999
    • 626
    Re: 56 distributor hold down and manifold holes
    Steve,
    I beleive the hold down is black, I have a 57 and I painted mine black and the judges in Laughlin did not ding me for it. The hole in the manifold near the rear carb in my car was chucking oil on the carb and the inside of the hood. I put a hex head, recesed unmarked bolt in the hole. The hole near the back of the manifold does not go all the way through. I would like to know from a judging type what is the proper set up. Is your 56 a single or two 4 set up.
    • Ed H.
      • November 1, 1999
      • 626
      Steve,
      • Steve Junkersfeld
        Ed, Thanks for the input. My car is a 2X4 and I would also like a judging opinion on how to handle those holes. Steve
        • Steve Junkersfeld
          • Bernie Schneider
            In my judging experience, the normal configuration is to have 1 hex head bolt installed in the hole that is tapped through to the lifter galley. The other hole is generally open with no bolt installed.
            • Bernie Schneider
              • Steve Junkersfeld
                Thanks Bernie *NM*
                • Steve Junkersfeld
                  Thanks Bernie *NM*
