I have a question regarding the draining and refilling of the radiator fluid. The service manuals say to drain the fluid from both the radiator and engine water jacket. Where on the engine is the bolt to be removed to drain the rad. fluid.? It is a '65 327/300.
I know there have been several discussions regarding the ideal water/antifreeze mix. I seem to remember most people go with a 50/50 mix distilled water/antifreeze. What brand of Antifreeze is most often used? I plan to check the archives on this subject.
Finally, do most auto parts stores take antifreeze? Or is there a preferred method of disposal?
Ryan
Ryan
