5 blade fan - NCRS Discussion Boards
5 blade fan
  • Jeff M.
    • February 1, 1999
    • 127
    5 blade fan
    Was a 5 blade clutch fan (ONLY TALKING ABOUT FAN BLADE) the same for a small block as it was for a big block. I need to rep[lace my blade and have access to an nos unit that is being sold as a 62-67 small block. From the pictures it looks like the same configuration of blade positions.
    • 43260
    Re: 5 blade fan
    jeff----
    The 61-67 small block 5 blade fan assembly, GM #3770529, is NOT the same as the 66-69 big block 5 blade fan assembly, GM #3888366. Both are 17-1/2" diameter and of 5 blade configuration, though. The GM #3888366 fan blade was used for all 1969 Corvettes, big blocks and small blocks, except those equipped with A/C.
    By the way, there are a lot of folks who have "access" to an "NOS" (depending upon your definition of the term NOS) example of the 61-67 GM #3770529 fan blade assembly. If you've got access to a GM dealer, then you've got access to the 3770529 fan blade assembly. It's still available from GM for a current list price of $63.20. Fewer folks have access to an NOS GM #3888366 fan blade assembly, though, since it was discontinued in April, 1971 and will very soon be celebrating the 30 year anniversary of its elimination from GMSPO inventory.
      • 43260
      Re: 5 blade fan
      jeff----
      • Jeff M.
        • February 1, 1999
        • 127
        JOE, what is the difference
        and can i use the small block fan blade? Does it use the same bolt pattern?
        • Jeff M.
          • February 1, 1999
          • 127
          • Roberto L.
            • January 1, 1998
            • 523
            Re: 5 blade fan
            Hello, last year I got one 366 replacement (Paragon I think) for my SB 70, which is virtually identical to my original damaged fan, check both side by side. Only minute differences in markings. Rivet and blade shape is correct.
            I checked a lot of places for original fans without much success, only original used fans, at very high prices and some doubts about critical state of alignment.
            It is labeled 66-69 BB but it is the same used in 69 SB, as Joe said and 70 SB too, as my manual trans no air car.
            Roberto, NCRS #30019, RMC
            • Roberto L.
              • January 1, 1998
              • 523
              Re: 5 blade fan
                • 43260
                Re: JOE, what is the difference
                Jeff-----
                I think the difference lies in the pitch of the fan blades, but there may be other differences, as well.
                Mounting pattern to fan clutch is the same and the fan could be used in your application.
                  • 43260
                  Jeff-----
                  • Peter L.
                    • May 31, 1983
                    • 1930
                    Re: 5 blade fan
                    Please double check but I believe the small block fan blade, P/N 3770529 is 17-1/8" dia. not 17-1/2" dia. Pete
                    • Peter L.
                      • May 31, 1983
                      • 1930
                      Re: 5 blade fan
                        • 43260
                        Re: 5 blade fan
                        Pete-----
                        Yes, you're correct. The GM #3770529 fan blade is, indeed, 17-1/8" in OD.
                          • 43260
                          Re: 5 blade fan
                          Pete-----
                          • Rob M.
                            • June 30, 1999
                            • 171
                            The BB fan has a blade pitch of 34.5 degrees if memory serves me correctly. I think the SM blade pitch is around 25 degrees.
                            My Project Pictures
                            http://temp.corvetteforum.net/classics/l78vetteman/
                            • Rob M.
                              • June 30, 1999
                              • 171
                              My Project Pictures
