Ignition Switch connector - NCRS Discussion Boards
  • Robert Holmes
    Two of the larger wire terminals in the plug that connects to the back of the ignition switch on my '68 have overheated and damaged the connector housing. The plastic has melted enough that the contacts won't stay in the plastic anymore. Does anyone know of a source for a replacement connector, or a good way to fix this?
    Thanks, Bob Holmes
  • Robert C.
    • December 1, 1993
    • 1153
    Re: Ignition Switch connector
    Call Lectric Limited, they have all the right stuff.
    • Robert C.
      • December 1, 1993
      • 1153
        Get two while you're at it!
        Something is 'rotten in Denmark' if you're melting plastic!!!! There's excess branch current being pulled somewhere and unless you find, trap, and kill the source(s) of the excess current drain, you'll be replacing the connector again. Last, I'd make sure I was totin' an on board fire extinguisher if I were drivin' this car....
