Steering Clearance - NCRS Discussion Boards
Steering Clearance
  • David Delnick
    Steering Clearance
    I'm putting my 61 together and after shimming the steering assembly outboard 1/4" I've only got 1/16 clearance between the steering sector shaft and the spark plug boot for #1 cylinder. The car has a 283 with stock mounts. Any advice will be greatly apperciated.
    David Delnick
    Member #12973
  • Ed Jennings
    Re: Steering Clearance
    I am not near my car and can't go look, but that doesn't sound right at all. Are the rubber motor mounts installed? It sounds like the motor is way too low.
    • Ed Jennings
      • David Delnick
        Ed,
        It has the stock mounts installed per the assembly manual.
        David
        • David Delnick
          Ed,
          David
          • Ed Jennings
            Any way you can post a picture somewhere?
            • Ed Jennings
              • Larry Allen
                David,
                I have about 1/4" clearance between the boot and the installed steering arm. If you have the stock spark plug wires with the 90 deg. head it should be okay. The clearance I'm talking about is directly forward of the plug head to the pitman arm.
                • Larry Allen
                  David,
