'57 Voltage regulator testing - NCRS Discussion Boards
  • Rex P Kelly
    I recently purchased a correct 001 voltage regulator for my '57. It looks good but I am not sure of is working condition. Can anyone please tell me of the correct testing procedures for it?......thanks
  • Jack H.
    • April 1, 1990
    • 9906
    Re: '57 Voltage regulator testing
    Two ways to go:
    (1) Install. Put voltmeter across battery, ignition off; you ought to see 12.6 VDC or so. Start and rev the engine up to 1000 RPM, voltmeter ought to climb to 14-15 volt range indicating V-reg is sensing the need to charge and instructing generator to put out.
    (2) Take the V-reg to an alt/gen repair shop in your area. They have a test/exercise machine where they can spin up a known good generator with your V-reg in circuit and verify it's cut-in/cut-out characteristics precisely (and tweak if necessary).
    • Jack H.
      • April 1, 1990
      • 9906
      Two ways to go:
