'56 Horn Test - NCRS Discussion Boards
'56 Horn Test
  • Steve Westphal #34441
    '56 Horn Test
    I have the original horns for my '56 but do not know if they work or not. Can I safely cross them on a 12 volt battery to see if they are good? Thanks.
  • Bill Clupper
    Re: '56 Horn Test
    Yes
    • Bill Clupper
      Re: '56 Horn Test
      Yes
      • Steve Junkersfeld
        But plug your ears *NM*
        • Steve Junkersfeld
          • Michael W.
            • April 1, 1997
            • 4290
            And make sure you don't reverse the polarity
            otherwise the sound will come out backwards and sound like "Knoh!"
            • Michael W.
              • April 1, 1997
              • 4290
              • Jim K.
                • August 31, 2000
                • 554
                That explains a lot!!! ;-) *NM*
                • Jim K.
                  • August 31, 2000
                  • 554
                  • Ted L.
                    • May 31, 1999
                    • 101
                    Re: '56 Horn Test
                    Be sure to use a pretty heavy wire, those horns pull a ton of current.
                    • Ted L.
                      • May 31, 1999
                      • 101
                      Re: '56 Horn Test
