exhaust stud crimp nuts - NCRS Discussion Boards
  • Richard Pressley
    Are the correct exhaust stud crimp nuts ('67 SB) supposed to be zinc plated or steel?
  • Dale Pearman
    Re: exhaust stud crimp nuts
    They're called, "Stover Nuts" and appeared in plain steel. The threaded holes are elliptical in shape and when installed are deformed to a circle to engage the stud. The elasticity of the steel, in trying to maintain an ellipse, clamps the nut to the stud much like a lock washer.
    Dale
    • Dale Pearman
      Dale
        When I restored my '57 four years ago, these nuts were still available from GM under P/N 3829086; don't know if they're still available or not.
            • 43221
            John-----
            That's the correct original part number for the exhaust stud nuts and they are still available from GM under that number. However, it's possible that the actual finish on the nuts may have changed over the years. So, if the originals were un-plated, the current-issue may be plated and vice-versa.
              • 43221
              John-----
