Point deduction help - sidepipe covers - NCRS Discussion Boards
  • JL66REDCPE
    At the last meet I attended, in Jenkintown, I incurred a 6 point deduction on Exterior Section 16 Rocker Molding or Covers - 2 originality and 4 condition. The sidepipes and the covers are in perfect condition. In the notes the judge wrote "rivets". The only rivets, (two of them) on the sidepipe system are on the front brackets where the bracket attaches to the sidepipe cover. The bracket is attached to the body via the proper screw. I can not find any other rivets anywhere. The rear attachment is via the correct attachment as well. Could someone advise me on what could have caused the deduction. There just are not any other rivets that I see. Two sections prior on the Grille section I recvd the identical deduction and I cant figure that one out either. All help is appreciated.
  • Robert C.
    • December 1, 1993
    • 1153
    Re: Point deduction help - sidepipe covers
    It's a little late now. The team that judged your car told you what the problem was and the reason for the deduction right after they judged your car. Always remember to ASK at the time about the deduction. Chances are a different score will occur the next time.
    • Robert C.
      • December 1, 1993
      • 1153
      • John L.
        • 409
        Bob
        Thanks for the response. It is not a question of too late. I am just trying to find out why so I can fix it if there is something not correct.
        • John L.
          • 409
          Bob
          • Robert C.
            • December 1, 1993
            • 1153
            John, I know what you're doing. I've been there. There are always a couple of things that don't look right on the sheets AFTER the fact that are probably perfectly understandable at the time.
            • Robert C.
              • December 1, 1993
              • 1153
              • Bill Stephenson
                ------Just a thought but are the rivets the correct ones?.........Bill S
                • Bill Stephenson
                  • Michael W.
                    • April 1, 1997
                    • 4290
                    The only person that can give a 100% complete
                    answer is the judge that assessed the deduction. Everyone else is second guessing. The judges name is on the sheet, why not contact him and ask?
                    • Michael W.
                      • April 1, 1997
                      • 4290
                      • Gary B.
                        • February 1, 1997
                        • 7024
                        John, are you using incorrect pop rivets?
                        John,
                        I've seen deducts on the grill attachment brackets based on the use of incorrect
                        pop rivets rather than the original rivet type. Do you have pop rivets by any chance?
                        Gary
                        • Gary B.
                          • February 1, 1997
                          • 7024
                          John,
                          Gary
                            Excellent suggestion!
                            In fact, the Team Leader and Meet Judging Chairman are on the Flight Score Sheets to help you here....
                            Adding to Bob Cook's comments, the human brain can process/remember 5 +/- 2 quickly presented, disperate items. Number (3, 4, 5, 6, 7) is strongly correlated to native IQ.
                            At a meet, the owner is presented with WELL over this number of items to mentally process. Many, go into sensory overload and tend to 'nod' their heads and agree during debrief, but the information is actually going into a trash can 'upstairs'....
                            A 'trick' that works is graphically encoding (thought to be how perfect recall individuals operate--take a 'picture' of the thingy). Ask the judges, time permitting, if there's another car with the 'correct' configuration they can show you. Once you've seen what 'correct' looks like, believe me, you won't forget later and struggle with terse comments on Flight Score Sheets later on....
