67 L79 stalls after 20 minutes - NCRS Discussion Boards
  • Jack H.
    • April 1, 1990
    • 9906
    Re: 67 L79 stalls after 20 minutes
    It's saying the charging system, by way of the voltage regulator is 'seeing' the battery to be dead as a door nail! This may or may not be true. V-reg could be seeing things that "ain't" due to faulty oxidized/corroded connection(s), V-reg could faulty, Etc.
    But, another clue given in the original post was the 'shop reported'.... So, if the car's in the shop under care/supervision of a paid 'expert', what the heck are we doing responding to the post with remote guestimate/diagnosis?????
    Shop mechanics should be earning their pay buy making sure the battery is fully charged before running alternator output analysis. Also, a number of references in this thread were made to 'the condensor'. There are a myraid of capacitors in the system, three specifically associated with 'funnies' in this area:
    (1) Condensor across points inside the dist cap.
    (2) Radio RF capacitor across coil to ground (if no TI).
    (3) Radio RF capacitor across V-Reg to ground.
    If any of these are electrically marginal (leaking internally), then as they pass leakage current they'll heat up and avalanche to passing more and more current. Those associated with the ignition process itself (points and radio coil), WILL show up like a sore thumb when the shop 'pro' puts the car on an engine analyzer and watches the ignition waveform over time....
    That's why it takes TWO measurements to assess the health of a capacitor: (1) measure the specific charge storage capacity (capacitance in fractional Farads), AND (2) measure the component's dissipation factor (when charging voltage source is removed, how much charge remains stored in the device after a brief time interval). Caps can test A-OK in #1 but be leaking like a sieve in test #2. Dissipation factor is expressed in percentage and readings of 1-5% are considered normal/good for most caps. Dissipation factors above 10% begin to indict the component's internal integrity....
    Few auto repair shops have the 'digi-bridge' test equipment to check energy storage electrical components (coils, caps). They tend to troubleshoot by rote component substitution. But, watching the spark waveform on an engine analyzer tells enough to find/stone the problem(s)....
    • Jack H.
      • April 1, 1990
      • 9906
      • Ed Jennings
        You mentioned in the original post that "points replaced with ignitor". I assume that this is a reference to a Pertronix Ignitor trigger. You also mention you have the stock ballast resistor. Everything I have read on the Pertronix unit suggests it is supplied with full system voltage and not the reduced voltage from the BR. How do you have your's wired? This said, I would also check out the 16V from the charging system. I believe your problem may well lie in one of these two areas.
        • Ed Jennings
          • Jim T.
            • March 1, 1993
            • 5351
            The only time I had to walk home in driving my original owner 68 L79 was back in 1976. The reason was the original coil. I don't remember which terminal on the coil it happened to, but one of the terminals would turn in the coil. I must of done this when I removed and installed the shielding for polishing. Replaced the coil problem solved.
            • Jim T.
              • March 1, 1993
              • 5351
