64 crossmember - NCRS Discussion Boards
64 crossmember
  • robert vargas
    64 crossmember
    Have installed new rubber cushions on the crossmember and have installed. Should the cushions be flush with the frame? I have tighted the two end cushion bolts with an impact and tried to get the cushions flush, but am having a problem getting things flush? Could it be the new cushions? I am about 1/8th of an inch off. Any ideas on how to get the bolts tighter? The cushions fit fine and the tabs have been bent over? Thanks
  • Gary S.
    • July 31, 1992
    • 1632
    Re: 64 crossmember
    I took my crossmember off of my 72 and reinstalled it this past week.
    I just walked down to the garage and looked at it. The crossmember is approximately 1/4" to 5/16" off of the frame. This crossmember is on a 33000 mile car and the rubber boot is still new looking with very legible numbers. I can assume that it is original.
    Gary
    • Gary S.
      • July 31, 1992
      • 1632
      Re: 64 crossmember
      Gary
      • Wayne C.
        • November 1, 1978
        • 289
        Re: 64 crossmember
        The cushions will not be flush with the frame... they fit over hat-shaped protrusions (trunated cones) on the frame and the bolts pull the inner part of the cushions snugly up onto the hats, not flush to the frame.
        • Wayne C.
          • November 1, 1978
          • 289
          Re: 64 crossmember
          • Dave K.
            • November 1, 1999
            • 952
            Re: 64 crossmember
            I installed new sombrero bushings into my rear crossmember on my 66 and noticed the same, i.e. a 1/4 -5/16' gap between the crossmember and the frame. I was also advised that this was normal.
            Dave Kitch
            • Dave K.
              • November 1, 1999
              • 952
              Re: 64 crossmember
              Dave Kitch
