58 Frame replacement - NCRS Discussion Boards
  • Chuck Lewis
    "Vettepeople", I need some info real soon as the '58 will be lost. There's a '58 in a yard around here and the owner said that I could have it if I cleaned his yard. The car is in pretty bad shape. There is an engine with two carbs, a fair interior with seats, hardtop, no chrome and moss over the lower part of the body, that's the good part. The frame is so rusted that I could stick my finger through it in places that should be solid metal. Now the question. Is there a replacement frame that I could use from another Chev auto that will work or do I need to get a '58 Vette only frame? I checked the archives but could not come up with the info. Thanks for your time and concern.
  • Ed Jennings
    Re: 58 Frame replacement
    You will need a solid axle Vette frame. They are available used or as new reproductions. Cost is generally $3-4K. Most are closer to $4K. Sounds like a real project, but the price is right.
    • Ed Jennings
      • Chuck Lewis
        Ed, Thank-you very much for the info. I'll concentrate on getting the car home for right now, then I'll go look for a bunch of roses. I'll need them when the wife gets home this pm. chuck
        • Chuck Lewis
          • Mike E.
            • February 28, 1975
            • 5138
            Chuck--
            Any 56-62 frame will work. (as will a 54 if you want to use an electronic fuel pump. There are variations on where/how rear bumpers bolt on, and whether or not there are rear radius rods or rear stabilizer bar, but they are essentially similar, especially if you're not doing an NCRS restoration. With the advent of the Newman chassis and others, it does seem that there are a few more solid-axle frames around--plus there are at least two excellent reproductions now available. You'll probably find that the frame is only one of many problems with a car that age--everything else will want to break off rather than back off. (And it's tough to take a torch to pieces mounted to the body to heat them before removing them). but--that's a no-brainer. Buy the roses, the help of some inexpensive kids (to both help with yard clean-up and car removal, and get that thing out of there! Good luck!
            Mike Ernst
            • Mike E.
              • February 28, 1975
              • 5138
              Chuck--
              Mike Ernst
              • Mike G.
                • April 30, 2001
                • 180
                New frame source
                Paul Newman from Car Creations sells a new reproduction frame for '53-'62s for $6k. He claims it's much better than the other reproductions. I can't say whether this is actually true, but I think I believe him. They are at (805) 226-9201 or www.carcreationsinc.com
                • Mike G.
                  • April 30, 2001
                  • 180
                  New frame source
                  • Chuck Lewis
                    Re: New frame source
                    Thanks guys for the immediate response with the info. Got the '58 home. I'm off do do some heavy yard work......chuck
                    • Chuck Lewis
                      • jim schultz
                        Call Joe Calcagno and talk to him, he specializes in solid axle corvettes and may have a used frame. His number is 831-475-4442.
                        • jim schultz
