Ecklers Side Exhaust Covers - NCRS Discussion Boards
  • Chris Burbage
    Ecklers is advertising side exhaust covers for 1965-1967 that are made from original GM tooling. Would these covers be the most correct of those currently available other than NOS or is there another vendor I should consider?
    Chris
  • Brandon K.
    • April 1, 1997
    • 474
    Re: Ecklers Side Exhaust Covers
    Eckler is the only one making these now, so anyone you buy them from got them thru Ecklers. The covers are almost exactly like the original ones. The only difference I could see was the glue used to hold the heat shield inside was not the same color. The new ones have glue that looks yellowish, while the originals had gray looking glue. I doubt you could see the difference once the covers are mounted.
    Brandon
    • Brandon K.
      • April 1, 1997
      • 474
      Brandon
      • William Wilke
        does anyone know where to get the glue to affix the insulator to the heat shield?
        • William Wilke
            • 11643
            Brandon,
            I believe that Paragon also manufactures side exhaust shielding for midyears.
            Patrick
              • 11643
              Brandon,
              Patrick
              • Chris Burbage
                Re: Paragon vs Ecklers Side Exhaust Covers
                Anyone have an opinion?
                Chris
                • Chris Burbage
                  Chris
                  • Brandon K.
                    • April 1, 1997
                    • 474
                    Re: Paragon Side Exhaust Covers
                    I could be wrong, but I believe that Paragon is getting them wholesaled thru Ecklers. The timing of the reproductions was just way too coincidental.
                    • Brandon K.
                      • April 1, 1997
                      • 474
                      • John S.
                        • July 31, 1990
                        • 292
                        I was told by a well know Corvette supplier that Eckler's cover's are being made by the very same company that made them for Gm.
                        • John S.
                          • July 31, 1990
                          • 292
                          • John S.
                            • July 31, 1990
                            • 292
                            Re: Ecklers Side Exhaust Covers REPRO?
                            I made a few phone call's today and no one has repro. 63-67 side cover's. It was told to me that Eckler's was having them made, but I called them and they no nothing about that. Any one else have any info. john
                            • John S.
                              • July 31, 1990
                              • 292
