Original or Replacement hoses for 67' bigblock - NCRS Discussion Boards
  • Rob Harper
    Who supplies the most accurate replacement hoses for a 67' 427? I am looking for the radiator (upper and lower), water pump, etc...
    Rob
    • 11643
    Re: Original or Replacement hoses for 67' bigblock
    Rob,
    For most of the hoses, there are only one or two manufacturing sources, and the rest buy from them. So, it is a matter of price from there.
    Patrick
      • 11643
      Rob,
      Patrick
      • Rob Harper
        Thanks Patrick.
        • Rob Harper
          Thanks Patrick.
          • Clem Z.
            • January 1, 2006
            • 9427
            just make sure that the bottom hose has the coiled wire support in it or it will be sucked shut by the water pump causing overheating.
            • Clem Z.
              • January 1, 2006
              • 9427
              • Rob Harper
                Thanks Clem. Are there repo bottom hoses out there without the coil? I'll keep it mind for sure.
                Thanks again,
                Rob
                • Rob Harper
                  Thanks again,
                  Rob
                    Rob -
                    There are LOTS of repro and replacement lower hoses out there without the spring, and lots of parts guys that will tell you they aren't necessary - they're wrong.
                      Rob -
                      • Clem Z.
                        • January 1, 2006
                        • 9427
                        john the first BB engine i built for a customer in 66 for a dirt track car had a heat problem so i went and had a looksee. what i found was a universal bottom hose that had a the wire molded into the hose but the hose was full size on both ends but was only about 1 1/4" diameter in main body of the hose restricting water flow. a stock chevy molded bottom hose fixed the problem.
                        • Clem Z.
                          • January 1, 2006
                          • 9427
