side exhaust - NCRS Discussion Boards
side exhaust
  • William Wilke
    side exhaust
    does anyone know how the inner fiberglass shield was affixed to the outer heat shield for the side exhaust on a 67 bb?
  • Wayne K.
    • December 1, 1999
    • 1030
    Re: side exhaust
    If I remember correctly they are bonded with some type of adhesive. I know in time they can come off probably from the heat.
    • Wayne K.
      • December 1, 1999
      • 1030
      Re: side exhaust
      • Bill Stephenson
        Re: side exhaust
        William,
        -----Its some sort of epoxy glue that mixes up to a gray color.You should be able to see it squeezing out from between the two peices on an original set!..........Bill S
        • Bill Stephenson
          Re: side exhaust
          William,
          • William Wilke
            Re: side exhaust
            i thought that it was an epoxy glue, but I was wondering what to use to get an original fit. I need to replace the fiberglass insulator for the shield on one side with a new one, and I don't know what to affix it with to make it original/or even stay. (I would think that any normal epxoy would break loose when you went over bumps.
            • William Wilke
              Re: side exhaust
