69 Speedo Calibration - NCRS Discussion Boards
  • George D.
    • August 31, 2000
    • 225
    I had to replace the odometer gears and the magnetic speedo coupling. I have been advised to have the speedo calibrated. Is this really necessary and if so, who does this type of work?
  • Chuck G.
    • May 31, 1982
    • 2034
    Re: 69 Speedo Calibration
    Yes, you should have it calibrated. The amount of magnetism on the spinning discs effects your speedo reading. Any speedo shop should be able to do it. They turn the speedo at a known cable speed, which translates into a known MPH reading. They then "gauss/degauss" the spinning magnetic disks to achieve the correct reading. Been there, done that. Took mine to Corvette Specialties of Maryland. Chuck
    • Chuck G.
      • May 31, 1982
      • 2034
      • Jack H.
        • April 1, 1990
        • 9906
        Most major metro areas have independent United Delco dealers and many are equipped with speedo service. Try your Yellow Pages.
        • Jack H.
          • April 1, 1990
          • 9906
