65-L76 Pulleys - NCRS Discussion Boards
65-L76 Pulleys
  • Mike M.
    • September 30, 1999
    • 710
    65-L76 Pulleys
    I have 2 Crankshaft pulleys with GM stamp and numbers on them. I was wondering if someone could tell me what they are used for or which is correct for my engine. This is a no air or power steering, it has the idler pulley. These are both 2 groove pulleys the numbers on each are 3858533 grooves are aprox 1/2in wide & 3744043-BA grooves are aprox. 3/8 in wide, both are 6 3/4in. diameter. Also is this the correct part number for the water pump pulley Gm#3871242.
    Thanks Mike
    Re: 65-L76 Pulleys
    Mike -
    I don't have a '65 TM&JG, but the '65 A.I.M. sheet for L-76 with the idler pulley shows the crank pulley as #3858533 and the water pump pulley as #3770245.
      Re: 65-L76 Pulleys
      Mike -
        • 43240
        Re: 65-L76 Pulleys
        Mike-----
        The GM #3858533 is the correct balancer pulley for your application. This is a 2 groove pulley of 6-3/4" OD. The pulley which you have that has the number 3744043 is actually pulley GM #3747479. This pulley was used for most 63-66 base engines. It is a 2 groove pulley of 6-5/8" OD, so it's just a bit smaller in OD than the 3858533. The GM #3858533 pulley is still available from GM.
        The correct water pump pulley for your application is the GM #3770245 that John mentioned and the pulley should be stamped with that number. It is a 2 groove pulley of 7-1/8" OD. At the moment, I don't know what application that the GM #3871242 pulley is for. However, I don't think that it's a Corvette application. The GM #3770245 pulley is still available from GM.
          • 43240
          Re: 65-L76 Pulleys
          Mike-----
            • 43240
            Re: 65-L76 Pulleys
            Mike-----
            GM #3871242 is not a water pump pulley, at all; it's an alternator pulley. Also, it's the correct one for your application. It has a 3-5/8" OD.
              • 43240
              Re: 65-L76 Pulleys
              Mike-----
              • Mike M.
                • 710
                Re: 65-L76 Belts
                Joe, Now that I have the correct pulleys the belts I have seem to be too thin.They ride down in the groove and appear to be riding on the bottom. The belts are from Quanta and the GM numbers I was told that were correct for my engine are GM# 3861946 Generator and GM# 3871258 idler pulley. The AIM shows a number of GM# 3871257 generator and the 3871258 as above for the idler pulley.
                Did they sell me the wrong belt for the generator. Also is the 3871257 the correct belt for my engine.Thanks to Joe & Jack for your help.
                • Mike M.
                  • 710
                  Re: 65-L76 Belts
                  • Mike M.
                    • 710
                    Thanks John *NM*
                    • Mike M.
                      • 710
                      Thanks John *NM*
                        • 43240
                        Re: 65-L76 Belts
                        Mike-----
                        The belts that Quanta sold you are correct. The GM #3871257 MAY have been used in PRODUCTION, but I think that the 3861946 was either also used or was actually used exclusively for the alternator application. The belts differ only slightly in length. The 3861946 is 54.0" long and the 3871257 is 54-3/4".
                        The reason that the belts appear to ride lower in the pulley grooves is that these are 3/8" wide belts. In the "old days", most GM V-belts were of the 3/8" wide variety. Later, GM replaced most of the 3/8" wide belts with 7/16" wide belts for SERVICE and for PRODUCTION after about 1973. Most aftermarket manufacturers did, too. So, the belts that you're used to seeing and likely the ones that your car was equipped with prior to your installation of reproduction belts were of the 7/16" wide variety. Either width belt will function perfectly with your original pullies. The 3/8" original belts were of "wrapped" construction; the 7/16" belts are of "cut" construction.
                        From a FUNCTIONAL perspective, which width belt is better? The 7/16" width, of course. GM didn't change to the 7/16" width belts for PRODUCTION because the 3/8" worked better. The 7/16" "cut" belts are stronger and more durable than the 3/8" "wrapped" type.
                          • 43240
                          Re: 65-L76 Belts
                          Mike-----
