58 front suspension interchange - NCRS Discussion Boards
  • Kris Schmalenberg
    Hello everybody. I need a front upper control arm for my 58. The thread in one hole is stripped. I know that 49-54 chev upper arms are the same. I know of a complete 54 front suspension that the owner doesnt want to split up. Does anybody know what other parts are the same? Are the lower arms the same? Thank you!!
    Kris
  • Bill Clupper
    Re: 58 front suspension interchange
    Before you go to a lot of work, have you checked the fit of available oversize upper shafts for your crossmember. If that doesnt work, here the interchange info, Upper and Lower a arm and shafts are the same. The crossmember has a couple of extra holes in the pass car version. The spindle (steering Knuckle) is the same, the support that connects the upper and lower a arms are unique to the Corvette, as is the steering third arm assembly
    • Bill Clupper
