Engine for 63 - NCRS Discussion Boards
Engine for 63
  • Stephen G.
    • January 1, 2002
    • 304
    Engine for 63
    Will an "870" 63 327/250 hp engine (stamp pad indicates it's from a 63 Impala SS) be a reasonable rebuild candidate for my wrong engine vette ? My cars not numbers matching now and it has a 72 350 currently. I'm just trying to rebuild something that's more correct historically.
    Steve Gansky
    Newtown, (Bucks County) PA
    • 43240
    Re: Engine for 63
    Stephen-----
    Yes, the Impala engine would be great. However, it would be best if it was an original Flint built engine and of proper date range. So, check the block stamp pad. If the engine production code begins with an "F", then you have an original Flint-built engine. If it begins with a "T", then it's Tonawanda-built. Tonawanda-built engines usually (but NOT always) also have a two-digit year year casting date on the bellhousing flange. That's the most important feature regading Tonawanda versus Flint-built engines. The block pad stamping can be removed by decking the block.
    In any event, the "870" block casting will be far more correct than what you have now.
      • 43240
      Re: Engine for 63
      Stephen-----
      • Bob R.
        • June 30, 2002
        • 1595
        Re: Engine for 63
        If you are trying to make the engine a 250HP it would work. That is the base engine size. If your corvette is a 300HP then the engine you are looking at has the wrong heads.
        • Bob R.
          • June 30, 2002
          • 1595
          Re: Engine for 63
