Good morning to all. In the 72 AIM, on page M268 (electrical) there is a description of how the speedometer cable goes into the transmission tail shaft. Item 9 says "Gear Chart". Other than relying on those of you with old GM parts manuals, is this chart listed anywhere? I can see what I believe to be is a red or perhaps pink gear sticking out. Secondly, item 5 is a fitting that the cable screws into, or the 90 degree adapter for those of us with 4.11's. Once the cable is off and the 7/16" nut holding the retainer is off, how does this fitting come out? Pull out, unscrew?
Last question(s). On page M214, under fuel, the AIM shows a "separator", item 1. Can one surmise that this is a fuel vapor separator since this is fed via a fuel vapor return line? What is it separating? Condensing fuel vapor back into liquid form? What is the second hose coming out below it, labeled item 5?
Sorry for the nit picking questions. I am just looking at things on the car and trying to do a little troubleshooting.
Gary
Gary
