Body Lift - NCRS Discussion Boards
Body Lift
  • Ray C.
    • June 30, 2001
    • 1132
    Body Lift
    I am ready to lift the body from my 1965 roadster. All bolts, straps and cable mounting clamps have been removed. Nolad Adams body lift work book states that the process can be completed with doors on or doors off. From those that have lifted a roadster body, is it better to remove or leave the doors mounted? Is there any other processes or tricks that I should know?
    Thanks for any help!
    Ray
    Ray Carney
    1961 Sateen Silver 270-HP
    1961 Fawn Beige 315-HP
  • Jeff Chester
    Re: Body Lift
    I left my doors on, put cushions between straps and doors.....
    jc
    or build a door support/bar...
    • Jeff Chester
      Re: Body Lift
      jc
      • Steve D.
        • September 30, 2000
        • 17
        Re: Body Lift
        Took the doors off first. They are probably coming off anyways and it is easier to remove them with the body on the frame as you want to limit the amount of torque that you apply to the body when it is unsupported by the frame.
        • Steve D.
          • 17
          Re: Body Lift
          • Donald O.
            • May 31, 1990
            • 1585
            Re: Body Lift
            Ray,
            I have always left the doors ON for roadsters and OFF for coupes. Leaving the doors ON for a roadster will provide for less flex until supported on a body dolly. With a coupe, the solid roof will provide the same bracing effect. Just my $.02
            Don
            • Donald O.
              • May 31, 1990
              • 1585
              Re: Body Lift
              Ray,
              Don
              • Bill Justman
                Re: Body Lift
                I took the doors off of my 69 vert during the body lift. I did bolt in some angle iron between the pillars. One side at the upper door hinge location. The other side at the latch post. This was to control flex while eleminating weight. I was suprised at how much the doors weigh. It was recommended to remove as much of the interior as possible first. I wish I hadn't. Now I have parts EVERYWHERE. Next time I would just remove the hood, doors, and top.
                • Bill Justman
                  Re: Body Lift
                  • Floyd Dossey
                    Re: Body Lift
                    Ray,
                    I agree with Don, I have a 65 roadster and when I did the body lift I left the doors on, it keeps the body rigid and supported. I didn't have any problems at all.
                    My 2 cents worth.
                    Good luck,
                    Floyd
                    65 FI
                    • Floyd Dossey
                      Re: Body Lift
                      Ray,
                      My 2 cents worth.
                      Good luck,
                      Floyd
                      65 FI
                      • Ray C.
                        • June 30, 2001
                        • 1132
                        Re: Body Lift
                        Thanks!
                        The posting are about even for doors-on vs. door-off so I guess I can't go wrong!
                        Thanks for all the advice!
                        Ray
                        Ray Carney
                        • Ray C.
                          • June 30, 2001
                          • 1132
                          Re: Body Lift
                          Thanks!
                          Ray
                          Ray Carney
