C1 Window adjustment - NCRS Discussion Boards
  • Paul Robinson
    I cannot get the passenger window all of the way down. My maintenance books describe how to adjust the "UP" distance, but not the "DOWN" distance. Any help?
  • Bob Malone #35242
    Re: C1 Window adjustment
    How far down does it go?
    • Bob Malone #35242
      • Paul Robinson
        It goes almost all of the way ... stops about 5 inches short at the door post.
        • Paul Robinson
          • John M.
            • January 1, 1999
            • 1553
            Paul, There is no adjustable stop at the bottom like there is at the top. at the bottom the window justs runs into a fixed rubber bumper at the bottom of the door. The most likely culprits are worn out rollers and a misadjusted rear run or center curved track. The rollers are available from a number of sources and the track adjustment is a matter of trial and error. I would remove the regulator first and assure that all rollers are in good shape and that the gear is in good shape. John
            • John M.
              • January 1, 1999
              • 1553
