Source for A Arm Bushings - NCRS Discussion Boards
  • John R.
    • September 30, 1999
    • 288
    It is now apparent that I cannot put off the front suspension work on my 67 coupe any longer. Does anyone know a source for the original style a arm bushings branded "Harris" with the rubber protuding on both ends? About three weeks ago Joe Lucia mentioned in a post that Art Dorsett of Van Steel in Florida may have made arrangements to obtain these. Does anyone know how I can contact Art? Any other sources that anyone else may have used? I have seen the correct lower bushings on ebay, but not the correct uppers.
  • Dave S.
    • August 31, 1992
    • 2926
    Re: Source for A Arm Bushings
    I bought my upper A arm bushings for the 67 camaro on ebay. I believe the Corvettes are the same as the Camaros. I have seen them since so keep searching and you will find them. They will run $60 to $100 for the four.
    • Dave S.
      • August 31, 1992
      • 2926
        • 43240
        John------
        The correct lower bushings are still available from GM under GM #3714368. It's the upper bushings that you have to go elsewhere for if you want the correct, exactly original configuration.
        You can obtain contact information for Art Dorsett through VanSteel's web-site at www.vansteel.com. Let us know what you find out; I'd like to know where they're at on this myself.
          • 43240
          John------
          • Brandon K.
            • April 1, 1997
            • 474
            I saw correct upper bushings advertised thru Long Island Corvette for $60 for the set.
            • Brandon K.
              • April 1, 1997
              • 474
              • John R.
                • 288
                LI Corvette's current catalog does list a set of upper A-arm Bushings "with inner rubber ring" for $60.00. I'll check with Van Steel and report back with a new post. Appreciate all the help.
                • John R.
                  • 288
                  • Jeff Chester
                    are you guys refering to the upper a-arm (top) bushing, or the bushings that go into the shaft, on the engine side? I need two top A-arm bushings/ with out the botl in type... Smash riviots...
                    jc
                    • Jeff Chester
                      jc
                      • John R.
                        • 288
                        Jeff, I was referring to the bushings that are pressed into the A-arms on the engine side. Are you referring to the ball joints? Doc Rebuild sells original ball joints for both the upper and lower A-arms.
                        • John R.
                          • 288
