61 spark plug shield L brackets - NCRS Discussion Boards
  • Ron R.
    • August 31, 1993
    • 159
    Which exhaust manifold bolts hold the 61 spark plug shield L brackets?
    My car is a radio delete, so, I don't have the sheilding to line up the holes.
    Ron
    23246
  • Bill Clupper
    Re: 61 spark plug shield L brackets
    Brackets are added as part of the Radio package, so no radio means no brackets either, for judging purposes. FYI, the AIM shows them in the second from the front and the second fron the rear
    • Ron R.
      • August 31, 1993
      • 159
      I must have been misinformed about the brackets.
      Ron
      • Dale Pearman
        All Engines
        were delivered to St. Louis with the french locks un-bent since manifold bolts were removed for installation of the "L" brackets. They were bent after the brackets were installed and manifold cap screws torqued. For that reason radio delete Corvettes appeared without bent-over french lock tabs.
        Dale.
        • Dale Pearman
          All Engines
          Dale.
