1982 Tires... - NCRS Discussion Boards
1982 Tires...
  • Richard B.
    • November 1, 2001
    • 58
    1982 Tires...
    I just visited my 82 in the storerom, and found a flat tire. It's a slow leaker, needing air once every few weeks in the summer. The tires are all original, 23,000 miles, and I have 2 spares of same. Is the tire damaged beyond safe driving? Is there a way to cure the slow leak? Should I just mount one of the extra tires and toss the flat one? I'm a little concerned about how long it sat on the flat tire this winter.
    Any help will be most appreciated!!!!!!!
  • Tom Freeman
    Re: 1982 Tires...
    Rich,
    I would not drive on 20 year old tires. Take those off and only use them for show. Then get a set of new ones for regular driving. Would really hate to see you loose a fender at 70 mph when the dry rot causes a blow out.
    tom...
    The '73 Spot
    • Harmon C.
      • August 31, 1994
      • 3228
      Re: 1982 Tires...
      A slow leak is usually fixable at a small shop with a car guy doing the work. I would use the tires you have now for show only if you plan any NCRS judging and buy a set of driving tires and rims as Tom said.
      Lyle
      • Richard B.
        • November 1, 2001
        • 58
        Replacement tires...
        Tom, Lyle: Thanks for the input. That's a mighty UGLY thought seeing a pristine fender shreaded by stupidity! There was some discussion here a few months ago of a place to get good replica tires. Can someone recommend a mailorder dealer, or will my local tire guy be just as good?
        Again, Thanks for the help!!!
        • Jim T.
          • March 1, 1993
          • 5351
          Re: 1982 Tires...
          The slow leak could very easily be a defective valve stem.
          • Richard B.
            • November 1, 2001
            • 58
            Re: 1982 Tires...
            Thanks, Jim. I agree, but after the mental image of the crushed fender, I'll be looking for a new set of tires AND valve stems!
            And Thanks to all for your help.
