C1 Gravity Brake Bleeding - NCRS Discussion Boards
  • Christopher R.
    • March 31, 1975
    • 1599
    Has anyone successfully bled their C1 brakes by using the gravity method?
    Re: C1 Gravity Brake Bleeding
    Chris -
    Nope, not that patient. Have always used either my MityVac or the "pump-and-hold" routine with a helper.
    • Clem Z.
      • January 1, 2006
      • 9427
      to gravity bleed you must leave to cap off the MC and this will let excess moisture into the fluid and this is a no/no. the least time the cap is off the MC the better off you are.
      • Ed Jennings
        I have successfully used one of those "one-man-bleeder" kits that you get at the auto parts store for $5. Has a lenght of clear tubing and a small bottle witha magnet on it. They really work quite well, and a re handy even if you are using the regimen with the helper. Keeps fluid from going everywhere. No success at all with the Mity Vac. Too much problem sucking air around the bleeder screw threads.
        • Patrick T.
          • September 30, 1999
          • 1286
          I have gravity bled my '57 and '67 many times, but I used DOT 5 Silicone fluid, so moisture was not a problem. It works well, if you're not in a rush.
          • andy#34338
            Clem, C1's have vent holes in the cap
            Clem,
            • Bob Malone #35242
              Okay, I'll bite. How do you gravity bleed a system?
              • Clem Z.
                • January 1, 2006
                • 9427
                just open the bleeders and go on a weeks vacation,when you come back it may be done. just kidding but it does take quite a while. just make sure you keep the MC full. the best way is to use a pressure bleeder you can rent from some large auto parts.i like the speed bleeders myself because it take all the open/close routine out of the equation.
                • Ted Stock
                  FYI - I've had good luck with a Mity Vac but you need to put teflon tape around the bleeder threads to prevent air from coming in around the threads. If you do that up front you can bleed an entire system pretty quickly with minimal fluid waste. And if you're using Dot 5 fluid waste even becomes more important. I bought a Mity Vac because of a brake system I couldn't get the ol' two person pump-hold-bleed method to work.
                  Ted
                  • Ted Stock
                    Ted
