New lower ball joint grease fitting popping out. - NCRS Discussion Boards
  • ERIC FAIRCLO
    Hello, I have a 72 corvette that my wife and i just installed a new front end rebuild kit. Everything went good but the lower ball joint grease fittings popped out when we tried to put grease in it. It like the grease fitting thread is too small for the ball joint hole. All the other grease fittings went in fine (tie rods, upper ball joints) All were self tapping threads. anyone have any suggestions how to keep the grease in the lower ball joints? Thanks in advance. Eric
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: New lower ball joint grease fitting popping ou
    they make different size fittings,some have threads and some are press in. check your local auto parts.
    • james Kekeisen
      Did you mix up the smaller tierod end grease fitting with the one for the ball joint which is a larger ninety degree one? My front end kit had some mixed parts in it ie some extra, some missing from their packaging.
      • ERIC FAIRCLO
        James, This is the one that is the 90 degree fitting. I made sure i kept them all in their seperate packages until we installed them. Thanks Eric
        • Gene M.
          • April 1, 1985
          • 4232
          Eric, Your mid year should be using a straight fitting with a self threading 1/4-28 fine thread in ball joints and tie rod ends.
          • Gene M.
            • April 1, 1985
            • 4232
            Re: correction grease fitting
            Sorry not a mid year but the thread size is the same in late model.
