67 fuel tank sender unit. - NCRS Discussion Boards
  • Richard S.
    • November 1, 1994
    • 809
    Before I install the AC Delco unit I just bought from Long Island Corvette Supply(6428065),is there some way I can test the unit to be sure it operates properly? Thanks.
  • Jack H.
    • April 1, 1990
    • 9906
    Re: 67 fuel tank sender unit.
    Long subject, lots in the archives on this thread. Basic resistance of the sender should vary in the 0-90 ohm range based on float swing-arm postion. But, for a full functional test you have to re-create the unique Whetstone bridge circuit topology of the gas gauge system that was used only on mid-year cars. This requires a bit of EE knowledge, a known good donor gauge, a wiring 'nest' with dual ground (at gauge as well as at tank sender), and a power supply.
    Just stop by the shop in Denver and I'll run 'er up for you. Other than that, you can either do a gross functionality test (ohm meter across sender) or go for broke--install sender and see what she does. BTW, diagnostics of gauge vs. items to troubleshoot is in the shop manual/chassis service manual.
    • Richard S.
      • November 1, 1994
      • 809
      Denver eh. Thanks for the kind offer but it's a wee bit far for me. looks like I'll have to install as is. Thanks for your help.
      • Richard S.
        • November 1, 1994
        • 809
