Shock Paint Color C-2 - NCRS Discussion Boards
  • Joel Karam
    I am looking for the proper, what will pass as OK, color to paint my shocks. The book says gray, I have heard blue-gray used? What color will be ok, i.e, will plan old gray enamel work, gloss, semi-gloss ???
    Thanks Joel
    67 Roadster
    PS Kylon is not available in my general area, I have looked.
  • Joe DeAngelis
    Re: Shock Paint Color C-2
    I purchased some shock absorber paint from an aftermarket company last year and it had their bar code description as "Shock absorber gray paint". It was in an aerosol can made by Seymour Paints and labeled as "16-117 Gloss Dark Gray". The look is somewhat blue-gray but mostly gray. I believe it is as a correct color. It should be available from any local hardware store that sells Seymour Paints. The coverage and look is excellent.
    • Loren L.
      • April 30, 1976
      • 4104
      More info needed
      about your car and its equipment. If it's a 63, gray or blue-gray is not correct.
      • Joel Karam
        NM : Thanks that Helps, 67 L71 *NM*
        • Gary B.
          • February 1, 1997
          • 7023
          Check out Quanta Products
          Joel,
          Check with Quanta Products for their shock absorber gray paint for Corvette shocks.
          Gary
          • Ron Booher
            Actually 63 shocks were semi to medium gloss black and later shocks were semi to medium gloss not quite dark gray. I mix my own paint to match some originals I have.
            • Robert C.
              • December 1, 1993
              • 1153
              Joel, one way to do this; Find an original Corvette at a friends', local club etc. with the correct color shocks. Get a paint sample book from your local paint store (one of those long skinny books with a million paint colors in them) find the correct match and take it to your local auto parts store and find a spray can that closely matches the correct color. That's how I did mine and I never got a deduction for color.
              • John Daly
                I judged '67 chassis at a regional meet here in New Jersey last year with
                some very experienced master level judges. The main items they were
                interested in was part numbers and dates and labels.
                There were not so critical on the shades of grey color.
                It's dark down there,even with a flashlight and a mirror.
                John
