C-2 AM/FM Dial does not Switch from FM to AM - NCRS Discussion Boards
  • Joel Karam
    AM/FM Radio Dial/Band face does not switch. It stays on the FM band when changed to AM. What is involved with repairing this? What is most likely gone wrong? I am hoping this is something that can be repaired by myself in a short time, the car is headed for the Regionals in two weeks. The radio operates fine with this dial/band exception. Oh, can the radio be taken out without major dash disassembly?
    Thanks Joel
    67 Roadster
  • Jack H.
    • April 1, 1990
    • 9906
    Re: C-2 AM/FM Dial does not Switch from FM to AM
    If radio sucessfully operates in both AM and FM modes, but front dial band indicator doesn't switch in synch, it's a mechanical problem in the tuner section of the radio.
    Could be as simple as a lock washer having fallen off the dial band selector arm (find it floating in the chassis, and reconnect) or a more serious problem as selector actuating arm has broken.
    There are threads in the archieves for pulling radio. If done correctly (read your Shop Manual/Chassis Service Manual), you can have 'er out reasonably fast.
    Once you pop the top cover and look at how the tuner section's AM/FM selector works (electrical switch with mechanical arms to flip dial band), you'll readily see what's wrong.
