engine noise - NCRS Discussion Boards
engine noise
  • johnybutler
    engine noise
    maybe one of you can help me!!
    when i first start my 79 vette
    about half way through warm up
    it makes a screeching noise for a short
    period of time until its warm.
    can you help????
    The ususal 'suspects'
    are PS pump, water pump and A/C compressor, assuming the car is NOT in motion during the warm-up period you mention. If you're in motion, other items could be responsible. A mechanics stethoscope can help pinpoint....
    • Pat Bush #35083
      Re: engine noise
      I agree with Jack. Typical screeching is usually a loose fan belt. Groan with steering is usually low PS fluid (indicative of another problem). Would not think it is an internal engine problem based on your symptoms.
      Regards -
      Pat
