1968 Hood Weatherstrip - NCRS Discussion Boards
  • John D.
    • August 31, 2001
    • 280
    Hi:
    When I got my 68 the Hood weatherstrip had been removed. I am going to replace it but the piece from Corvette Rubber is a lot longer than the hood is wide. Does it continue around towards the front along the sides??? Would anyone have a picture or diagram of where the strip ends???
    Thank you, John
  • Jim T.
    • March 1, 1993
    • 5351
    Re: 1968 Hood Weatherstrip
    John having a original owner 68 I just measured my original factory installed weatherstripping. From the tip of the hood on the drivers side using just a tape measure the end is 15 1/2 inches from this measuring point. I did not measure the passenger side.
    • Robert C.
      • December 1, 1993
      • 1153
      John , the rubber turns forward at the hood corners and goes down the side towards the front about 12-18inches. Use the yellow glue.
      • John D.
        • August 31, 2001
        • 280
        Thank you both for the help. *NM*
