'67 Steering Column - NCRS Discussion Boards
'67 Steering Column
  • Scott Marzahl
    '67 Steering Column
    Well I'm getting my '67 steering column back together and I just received a used plastic cover that covers up the collapsible portion of the column. How do you secure this cover it in place?
  • Mike M.
    Director Region V
    • August 31, 1994
    • 1463
    Re: '67 Steering Column
    The two halves have a groove inside the steering wheel end that fits over a ring on the collar.
    Each side of the bottom half has a recess for a #6 phillips head, black phos machine screw, 7/8" of threads, that attaches upward into the top half. (Any longer will protrude up through the top and/or crack it). That's it! Probably alot information than you needed.
    Incidentally, that cover is not painted, it remains in the natural plastic finish, sort of a dark chocolate brown/Black, not the crisper semi-gloss black of the collar.
    There may also be smoke streaks running through it.
    H. a. N. D.!
