wiper switch sparking - NCRS Discussion Boards
  • Jimmy Roggenbuck
    When I go to use my wipers and depress the button there is a small visable spark. The wires seem to be fine ? any help is appreciated.
  • Frank O.
    • January 1, 1997
    • 19
    Re: wiper switch sparking
    Check your housing that your wiper switch is mounted in if it cracked or in two parts it isn't grounding properly. I had the same problem on my 71. I brought a new housing which corrected the problem.
    • Gary S.
      • July 31, 1992
      • 1632
      My neighbor's 73 had bad wipers and would often blow the fuse. When he pulled the panel he found a wire with broken insulation. That solved the fues problem but the wipers still didn't work. We found that it didn't have a good ground. Instead of tracing all of the wiring back into the dash harness, he fabricated a simple ground from the switch to another known ground. Been working well ever since.
      Gary
