62 Fuelie - NCRS Discussion Boards
62 Fuelie
  • Todd Pollock
    62 Fuelie
    I have a 62 Fuelie I have had for about a year. When driving it at rmp above 2700 it gets jerky and sounds like it is misfiring. The FI is very original and I didnt know if there are any common problems/ parts that wear out and my cause this problem. I replaced the filter and that had no effect. It revs in nuetral fine. The engine is also fresh. Any suggestions appreciated, I am new the FI arena.
  • andy#34338
    Re: 62 Fuelie
    Sounds like ignition and not fuel but it could be fuel. You may want to check for cracks in you distributor cap or burned spot in one of your plug wires. What shape is your distributor in?
    Fuel distribution issues may create an issue like that (not enough fuel to the injection unit)
    • Ed Jennings
      Re: 62 Fuelie
      If ignition checks out, check condition of fuel pump drive cable.
      • Ed Jennings
        To be more specific,
        check the ends to see if they may be rounded to the point that the cable will slip at higher RPM. Most likely your difficulty is electrical.
        • David Dawdy
          Re: To be more specific,
          Take a close look at the distributor, the weights may be hanging up at high rpm.
          Make sure they are free and the springs are correct.
          • Richard T.
            • February 1, 1979
            • 858
            Re: 62 Fuelie
            Todd,
            It sounds like an ignition problem to me . Don't tear into the injector until your positive that your points ,plugs, wires , and valve lash are up to snuff. I've been driving my F.I. 62 almost 30 years and every problem that I've had over the years was ignition or cam related. It's tempting to blame the unit but I've found them to be very dependable over time as long as their kept clean and all vaccuum connections are leak free. Take your time and good luck. Rich #2276
            • Todd Pollock
              Encouraging news
              Thanks for the input. I am glad to hear that odds are not the unit. I really hate to touch that guy. I will search out some new electrical parts. Thanks Again. It was my first time using this board and it seems great.
              • Dale Pearman
                Re: 62 Fuelie
                How many miles ya got on that crate Rich? I got 335,000 on my 62 Fuelie in 24 years! Fuel units reliable? HA! HA! Just like a Smith & Wesson. I've NEVER had a problem except for leaks.
                Dale.
                • Richard T.
                  • February 1, 1979
                  • 858
                  Re: 62 Fuelie
                  Dale,
                  It's over 100K but I'm not sure cause I had no odometer for a long time . It was retired to weekend or pleasure use in the late 80s and I think that's worse than the daily driving. If I remember correctly the only true F.I. problems were a leaky high pressure pump seal , one bad cranking signal valve (real smokey)and a couple of times I had cracked nozzles block hoses and finally learned to check em every once in a while cause they go bad on the surface that faces the intake and can't be seen. The hot restart problem has always been there but one or two blips of the throttle and all's well again. Oh yea ! I had to replace the distributer seals once . That's it ! All in all I think the general did a good job on these cars. I'll email you a picture . Later Rich
                  • Bill W.
                    • March 1, 1980
                    • 2000
                    Re: 62 Fuelie
                    check the weight plate on your dist. mine had the same problems as yours .the plate was stuck. bill
