67 37amp voltage regulator P/N - NCRS Discussion Boards
  • Scott Marzahl
    Does anyone know what the correct configuration / P/N is for a Delco Remy voltage regulator for a '67 with a 37 amp alternator is.
    Scott Marzahl
    Re: 67 37amp voltage regulator P/N
    You got lucky! After '63, the standard v-reg was the '515 part which is common to all Chevy passenger cars. It should be as easy as finding a scrap yard with an untouched Delco Remy '515 v-reg still attached to the firewall, checking the date, taking it home and cleaning it up for your Corvette!
    • Page C.
      • February 1, 1979
      • 802
      Hi Scott,
      Like Jack said those regulators are common to all old Chevy.s. They are also common to most all GM cars for those years. Check those Buick's, Oldsmobiles, Pontiacs and GM pickups. Also check behind the back seat for the build sheets. They were placed in the rear seat springs. They will give you the dealer zone and code for that car. Alot of the GM dealers were Chevy/Olds, Chevy/Buick, etc. You can then ad this to the NCRS dealer codes.
      Hope the helps
      Page Campbell
