Car, 67 Roadster, have the Trico WSW Arms/Blades. Have new replacement rubber blades and could use help with how to feed them onto the metal ribbon. Is there a trick to getting the new ones on? I have been able to slide them through from one end which left me with a section in the middle where two small pins are crimped and the end where I started not in place? I am being careful as I do not want to tear and toss a new blade! Note, the old blades show the indention from the center crimped tabs around the blade retention rib.
Thanks Joel
Thanks Joel
