WCFB carb needed - NCRS Discussion Boards
WCFB carb needed
  • Phil Fischer
    WCFB carb needed
    I am converting to a dual quad manifold on my 61' Vette. Does anyone know of a source for the secondary carb, or would removing the choke assembly, and butterfly, suffice to use as a front carb? My car is a driver......Phil
  • Steve Junkersfeld
    Re: WCFB carb needed
    Phil,
    I built a 2X4 setup for my brother's 56 Chevy using a GM aluminum manifold and two generic WCFBs - the front one was a passenger car carb with the choke removed. The setup ran great and provided the desired look and retro appeal. Keep in mind that you may end up having to jet down one or both of the carbs depending on their original application and the throttle linkage may require you to drill and modify the bellcranks. Good luck, Steve
