Quadrajet Primary Throttle Plate Holes - NCRS Discussion Boards
  • Roger S.
    • May 31, 2003
    • 262
    Has anyone drilled small holes; 1/16", in the primary throttle plates to allow the car to idle properly and have the idle screws function?
    Roger
    Drilling Q-Jet
    If memory serves, there's a thread on this in the HP book on Q-Jet available from the NCRS library (store--this site) in their chapter on modifications for race/performance....
    • Clem Z.
      • January 1, 2006
      • 9427
      Re: Quadrajet Primary Throttle Plate Holes
      yes you can drill the holes but if you have a hot cam you will need to drill the idle/air bleed screws out to about .090 and drill the idle feed restrictions and these are in the doug roe book.
