56-57 Leaf Springs - NCRS Discussion Boards
56-57 Leaf Springs
  • Steve Michael
    56-57 Leaf Springs
    I have a 57 VIN with numerous pieces from 56 as well. The numbers on my leaf springs are 3711550 and 86E6. Does anyone know if these are correct? Are they the heavy duty leafs, and if so, what would they sell for? Any assistance would be greatly appreciated.
  • James F.
    • December 1, 1985
    • 596
    Re: 56-57 Leaf Springs
    Steve,
    The stamped number is probably 3711650. The 86 means the 86th day of manufacture, the E stands for Eaton (who made the springs) and the 6 is for year 1956. For a street driven '57 I see no benefits to the heavy duty springs. Regards,
      • 43203
      Steve-----
      As far as I know, the GM #3711550 rear spring was used on both 56 and 57 models. This is a 4 leaf spring and was used with the "standard" suspension, not the HD. I think that the HD spring was GM #3748143 and was of 5 leaves.
      • Mark S.
        • July 31, 1983
        • 659
        Steve:
        They are 56 springs. I sent you an e-mail. Mark
        • Dale Pearman
          You have a PRODUCTION set of original four leaf standard springs (550) made in 1956. In later production (1956-57) the number changed to 438 (last three digits) and continued until the end of C1 production. The five leaf springs were 143. Also there was a service replacement five leaf spring with the same part number but a different configuration.
          Your stock springs probably have an extra leaf added for improved strength.
          Dale.
          • Steve Michael
            Thank you all for the responses. Mark, I'll call you tonight.
