Cleaning method for case of transmission? - NCRS Discussion Boards
  • Jason Conn
    What method is best for cleaning grime off my M22 (out of the car)?
    I've elbow greased it as much as possible to get this far...I was planning on blasting (glass bead) the other tough parts to give it a 'new appearance' until I saw the post about blasting aluminum. Is the case aluminum or that potmetal material? Any suggestions?
    Thanks as always, Jason
  • John L.
    • February 1, 1982
    • 35
    Re: Cleaning method for case of transmission?
    I used a scrub brush and Simple Green on my T-10 aluminum case and it really cleaned up nicely.
    • Gary S.
      • July 31, 1992
      • 1632
      Ditto on the Simple Green and a hard bristle brush. I use it in a fairly strong strength and it will clean quite well.
      Gary
      • Steve D.
        • February 1, 2002
        • 990
        Where can Simple Green be purchased ?
        • Dick C.
          Past NCRS President
          • November 1, 1995
          • 454
          Target, Home Depot, Lowes or any other similar type store
          Dick Capello
          New England Chapter/Mid Atlantic Chapter
          Past NCRS President
          Past Region 1 Director
          • Jeff Broughton
            I've also used brake cleaner to blast the grime off....and I've heard that the Eagle One etching mag wheel cleaner works well, too.
            Both available at Auto Zone, Advance, etc.
            Hope that helps!
            Jeff Broughton
              The Eagle One stuff you want is "Etching Mag Cleaner" for rough cast alloy wheels - has a "B" uniform wheel care symbol, not to be used for polished aluminum - their #1010626. Also pretty effective on stained old aluminum valve covers. Be sure and read the "Cautions" panel - it contains hydrofluoric acid, phosphoric acid, and sufuric acid - use outdoors, safety goggles and nitrile rubber gloves mandatory. Nasty stuff, but it works.
