'67 Non PB Master Cylinder Color... - NCRS Discussion Boards
  • Patrick T.
    • September 30, 1999
    • 1286
    What shade of black is the master cylinder? The NCRS Judging Manual does not seem to address this issue. Thanks, Patrick #33001
    • 43221
    Re: '67 Non PB Master Cylinder Color...
    Patrick-----
    It's a "semi-flat" black. I'd describe that as being just a little flatter than what we think of as "semi-gloss" black. I believe that the castings were painted before machining so that the machined surfaces are un-painted.
    By the way, for 1967, all master cylinders, except those used for J-56 HD power brakes, were the same. The painting scheme, though, was the same for ALL.
    • Patrick T.
      • 1286
      Thanks Joe, I just happen to have a can of Krylon Semi-Flat right here. Patrick
        • 43221
        Patrick-----
        Yes, that will do. However, keep in mind that glycol-based brake fluid (DOT-3 and DOT-4) will quickly destroy most paints which they contact. If you use silicone-based DOT-5, there is no problem (although the silicone fluid will make semi-flat paint appear glossy if it gets on it).
