Electrical/Headlight problem on '90 Conv. - NCRS Discussion Boards
  • 71vette
    I have 3 problems which may or may not be related. 1) High beam indicator stays on when headlights are turned on, 2) Right front headlight is very dim (bulb has been replaced) but left headlight operates perfectly (high & low beam), 3) Right side horn button on steering wheel doesn't work. Since I know NOTHING, hopefully someone can steer me in the right direction.
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: Electrical/Headlight problem on '90 Conv.
    By chance do the turn indicators also stay on or at least partially when the headlights are turned on?
    I would check the ground wiring at the dim headlamp.
    • George #32871
      That solved the dim headlight and the high beam indicator problem. Thanks a lot, Wayne.
