65 radiator #'s/code - NCRS Discussion Boards
  • Jimmy Roggenbuck
    Where on the radiator can you find these codes and what if anthing must be removed. What are the correct ones for this year?VIN #194675S120082
  • Bill Clupper
    Re: 65 radiator #'s/code
    The date cone is an alphanumeric code stanped into the top surface of the radiator, a few inches toward the passenger's side from where the top hose connection is. A typical date for a car in yur serial nember range would be F65 or G65
    • Jimmy Roggenbuck
      Re: 65 radiator #'s/code Thanks NM *NM*
      • Thomas D.
        • May 31, 1987
        • 121
        Actually the dating format is year/month, not month/year. And being #20000, your car was built in June, so the latest date possible would be 65E for May and/or 65D for April. F would be the same month as the build date which isn't typical and G is after the build date. Part number is 3155316.
