C1 wiper transmission repair? - NCRS Discussion Boards
  • Dave Christensen
    The clutch mechanism on one of the wiper transmissions on my 56 is stuck together. Is there an easy way to get them to separate or do I need to take it apart?
    Assuming that I need to take it apart, should I remove the top stake or the bottom stake?
    thanks
    Dave Christensen
  • Ed Jennings
    Re: C1 wiper transmission repair?
    Before you disassemble, fill a small jar with penetrating oil and soak the bottom end of the transmission for a couple of days. Unless it is severely corroded, you probably will be able to free it by gently tapping the shaft down with a non metalic hammer. You may have to tap it in both directions multiple times to get the mechanism free. Repeated soaking/tapping has always freed the ones I've delt with. Some were harder than others and took longer.
