63 Fiberglas Rear Spring - NCRS Discussion Boards
  • John Fleming
    I'm installing the original differential in the car and I'm at the point now
    where I will be installing the rear spring. The car came with a TRW fiberglass
    spring, and I was wondering if there were any differences (in installation) between an original, and the fiberglass? Thanks for any help.
  • Ed Jennings
    Re: 63 Fiberglas Rear Spring
    The fiberglass spring must be shielded from the heat of the exhaust. Heat shields should have come with the spring and hopefully are installed on the car already.
    • John Fleming
      Ed, The spring link bolt was 1&1/2" up from the bottom of the link bolt (where the cotter pin hole is) when I removed the spring. Do you think that was right? I can't trust how anything in this car was put together by the previous owner. Thanks
      • Ed Jennings
        John, A lot of the springs are supplied with longer-than-stock bolts so you can adjust the ride height. It sounds sort of like that is what you might have. Does the car sit level? I have never installed a fiberglass spring, but when I have replaced a metal spring I was sold some longer bolts to keep the rear of the car from being too high. As it turned out, I couldn't get the rear highe enough with the longer bolts and ended up putting the originals back in.
        • John Fleming
          Ed, The car did sit level. Thanks for the info.
