distributor date code ?? - NCRS Discussion Boards
  • Howard Nardick
    I have a 1111069 distributor, date code reads 6K4 ,should be october 4 1966 but the distributor part number (069)is for a`64-65 327/365 hp distributor.Was there a`66 327-365hp motor? Or possibly is this an "over the counter" deal? Thanks in advance HN.
    • 43221
    Re: distributor date code ??
    Howard-----
    There was no 1966 L-76 (365 hp/327). What you must have is a SERVICE distributor. These were manufactured and available for many years after the L-76 ceased to be.
    • Howard Nardick
      Thanks *NM*
        • 15677
        The 069 was the best calibrated OEM distributor Chevrolet ever made for the SB.
        I gave 24 degrees of centrifugal advance, which was all in at 2350 engine revs, and the vacuum can gave 16 degrees at 8 inches Hg.
        This is a perfect calibration for a SHP engine that only idles at 10-12 inches Hg., but I think the aggessive centrifugal advance would not make a SHP engine happy on today's pump gas octane ratings.
        This distributor was phased into production during the '64 model year and carried through to the end of '65. A companion distributor with a pump drive and the same calibration was used on FI engines from mid '64 through '65.
        I've always been curious as to approximately when the 069 showed up on '64 L-76 engines, but I don't have any data.
