Shermersheim Front Clip?? - NCRS Discussion Boards
  • John Farwell
    Does anyone know how to contact or the correct spelling of Shermersheim?? I think he is in Indiana and his first name is Jim. He's the guy who supposedly makes pretty good fiberglass front clips and other body parts.
    Would anyone not recommend his front clips? Many people recommend corvette image but they are so much more expensive.
    Thank You...John
  • Myles Kukurudz
    Re: Shermersheim Front Clip??
    Hi John,
    Jim Sermersheim (812)424-4701, I bought a Fan Shroud and a fender from him and the quality was top knotch. I also bought a front clip for my 67 from ACI which fit really well.
    Regards Myles
    • Wayne W.
      • April 30, 1982
      • 3605
      BTW midyear fan shrouds are now available from Corvette Image and are topper knotch.
      • Joe C.
        • August 31, 1999
        • 4598
        John:
        If you are looking for authenticity, then Corvette Image is the only way to go. Shermersheim's panels are good quality for a "driver", but are gelcoated inside and out, which is great for protection, but a no-no for the show circuit.
        Joe
        • Gary S.
          • July 31, 1992
          • 1632
          Joe, more out of curiosity than need, how can you tell that a panel has been gel coated once it is painted on both sides? Other than that, are the panels good?
          Gary
          • Don Shirey
            John,
            Corvette Image supplys the PM panels for vendors such as CC
            and Eckler's, which will give you a 10% discount.
            Good Luck,
            Don 31553
            • Wayne W.
              • April 30, 1982
              • 3605
              You certainly can tell on any underside surface where there was no priming and sanding preparation. The coloring is also a factor and whe original panals were sandblasted around the bonding areas. On Shemersheim`s panels where the gelcoat is knocked off by this process often exposes bubbles and voids that show.
              • Joe C.
                • August 31, 1999
                • 4598
                Gary:
                It depends on which panel we are talking about. The following panels are to be left unpainted inside, and are sublect to scrutiny for Flight judging:
                Taillight panel
                Quarterpanels (parts outside the wheelhouses)
                Exhaust filler panel
                Rear deck
                Front lower valence panel
                Front nose lower center panel
                Front surround (in the area of the header bar)
                Floor pan (except in the forward part of the trans tunnel)
                Joe
                • Brandon K.
                  • April 1, 1997
                  • 474
                  Sermesheim JUNK
                  I've been doing some 'glass work on a car with a lot of Sermersheim replacement panels on the front, and there is not enough resin content in the panels. In my opinion, they are crap (pardon my French). Full of holes and areas of dry cloth with absolutely no resin in between. I have debated ripping the panels off and junking them for new Corvette Image panels, but I already have too much time and money invested. Do yourself a favor, spend a few dollars extra and get the Image front end, or even a hand-laid one piece!
                  Brandon
